How to increase the life of a battery
Discussion in 'General Electronics Chat' started by 6860, Mar 24, 2007.
Thread Status:
Not open for further replies.
  1. 6860
    Mar 22, 2007
    How long a battery can be kept under charging?What is the difference between ordinary charging and booster charger?How to increase the life of a battery?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. hobbybuilder
    Member
    Mar 24, 2007
    16
    Hello 6860, I have just had the same question setting up an alarm that needs to deliver 10 Amps at 12V, independent from mains power. Now as I understand, quick-charging (booster-charging) a battery, i.e. applying a high amperage during the charging process, will reduce the life of the battery. Trickle-charging (ordinary charging), on the other hand, i.e. applying a very low amperage over a longer period of time, will enhance battery life. Now an ordinary charger (trickle charger) monitors the voltage of the battery, and when the target voltage is reached, switches off automatically. If the voltage drops under the target voltage, the charge delivers power again. So a trickle charge is more than just a transformer, it senses the volage and switches on or off accordingly. That's how I understand it anyway. Hope that helps.
  4. 6860
    Mar 22, 2007
    thanks for your replies.what i mean is a 12 volt battery used in the heavy equipments or heavy vehicals has to be maintained for its reliability.what actions can be taken to maintain that?please list out.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Standard or deep-cycle?
  6. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Most lead acids don't like being kept in a float charge state indefinately.
    Nor do they like being over charged, nor do they like being left in a near flattened condition.
    They are a few multistage chargers out there that monitor the battery voltage and adjust the charge conditions to suit.
    Cyclic chargers switch off the charge when a voltage between 13.5 - 14 volts (depending on Batt and app) is reached at the terminals. Most of these resume charging when the voltage drops below 12.5 or so... again depending on design. These are useful for standby batterys as used in alarms and emergency apps.
  7. tesla0157
    Aug 6, 2015
    8
    (de something?????? cannot remember the name of this water) water would help to mantain battery life where it would not get hot ******but not regular drinking water**** it has clorine in it. also you can clean out with allum and magnesium if battery gives problem (you tube) uses this to regenerate a battery $5.00 repair . as far as maintance on heavy equipment if it does not perform, it is gone and another is replaced. i was a service man on hvy eq
  8. blocco a spirale
    Jun 18, 2008
    1,462
    370
    8 years later! what took you so long?
  9. BR-549
    Sep 22, 2013
    2,184
    421
    It might be worth it.
    I want to hear about that $5 battery repair.
  10. tesla0157
    Aug 6, 2015
    8
    check (youtube) (5.00 battery repair ) it can be used with the allum and magnisum and it will work. I would use this to clean battery and wash out many times . Put in new acid and water this will rejuvinate the battery.
  11. tesla0157
    Aug 6, 2015
    8
    P.S. I just found this site today.
  12. #12
    Nov 30, 2010
    16,705
    7,358
    @tesla0157
    The important message for you is that very old conversations generally do not benefit from your input because the original participant probably will not see your work. This site does not strive to be an all encompassing encyclopedia so much as it strives to serve people with specific questions. As a general method, working with only the Threads active in the last few days is practical.
  13. tesla0157
    Aug 6, 2015
    8
    ok i am new and i did not check date you are the third person who has slamed me for this newbe mistake WOW !!
  14. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Old thread, now dead
Thread Status:
