How to increase AC voltage of solar cell/panel
Darius Jermala
Joined Dec 14, 2015
Hello eveyone,
I‘m making imittation of solar panel voltage imput (solar radiation) + DC/DC converter + DC/AC converter (With LTSpice software):
In the scheme below it is generated AC voltage of 1 solar cell (between Vabc and Vxyz dots):
[url=http://postimg.org/image/7czrcw93j/][img=http://s3.postimg.org/7czrcw93j/2_V.jpg][/URL]
The idea is to gain 220-230 RMS Voltage to power up for example water pump. So the Vpp has to be 170V. So the AC signal should look like this:
Does anyone could help me to increase Vpp voltage from 2V to 170V? Maybe you have any idea how to multiplie cells connected sequentialy with 1 DC/AC converter? (Because I don‘t think so that every cell has it‘s own converter, or does it?) Or it will be enough to upgrade DC/DC converter to increase Vpp?
Thank You in advance!
MikeML
5,444
Why not do what everybody else does; stack up a series-connected set of cells to get >24V, and then use a step-up smps.
Picbuster
Joined Dec 2, 2013
1,047
hmm, you stated 3.3V@ 10mA = 0,03 Watt using a step-up loss 10% waterpump 0,027watt pump power available.
fact;to bring 75liter water 1 meter high in one second you need 736Watt 1pk approx.
now you can calculate the time needed to bring 1 liter of water 1 meter up.
Darius Jermala
Joined Dec 14, 2015
And what about if after pumping 1 liter to 1 meter height I would like to disconnect solar panel from water pump and I would like to sell electrical energy via grid ? I would still need 170V AC ? Is it possible to modify this circuit somehow to gain 170V? Because requirement is to use DC/DC and DC/AC converters in circuit :/
AnalogKid
Joined Aug 1, 2013
11,036
240 Vrms = 170 Vpeak, not Vp-p. 240 Vrms = 340 Vpp.
What requirement?
Stepping 2 Vdc up to 220 Vrms is going to be *very* inefficient.
ak
Picbuster
Joined Dec 2, 2013
1,047
no problem to make 170V but the power will be no more than 0,027watt
gives you @170V 0,00015A no pump will run not even a led will go on.
Conclusion; project is useless.
