How to include LTspice simulation folder
Discussion in 'The Projects Forum' started by wayneh, Nov 2, 2015.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,368
    3,224
    I want to use the TI op-amp TLV272 in a simulation. The Spice models offered by TI are folders containing three files, with .lib, .tld and .tsm extensions.
    I've only used single-file include files in the past, with the ".inc" directive, and don't know what to do with a folder full of files. Including only the .lib file caused errors.
    Preparing for a forehead slapping moment. :confused:
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    The dopes at TI have privatized their models, and even encrypted most of them is such a way that they run only in a proprietary simulator... They claim you can download a "free" version to run their models, but when I did it, I kept getting "offers" to buy a commercial version of the simulator... (Adware?)
    I did find some PSPICE models for the TLV272. Also something specific to LTSpice, here.
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    Do you mean the ones at TI? Those are also folders instead of single files. The .asy file is for the symbol. I don't think that's my problem.
    TI is screwing the pooch with this.
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    I grabbed the linked .asy file, saved it in my >LTSpice path, and built this:
    Just put the .asy file in the same subdirectory as Draft294.asc, and it should run for you...
  5. wayneh
    Sep 9, 2010
    12,368
    3,224
    Yeah, I just tried it and it does indeed work. Thanks.
  6. eetech00
    Jun 8, 2013
    676
    116
    Here is a TI version.
    Just unzip and open the .asc file
    Spice model is in the .zip
    wayneh likes this.
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    Well that's cool, and it works! Seems to have a lot more detail and nuance than the .asy file floating around. Where did this come from? I couldn't find it at TI.
  8. eetech00
    Jun 8, 2013
    676
    116
    It's on the TI data sheet.
  9. wayneh
    Sep 9, 2010
    12,368
    3,224
    Well there's the forehead slap I was looking for: Read the f-ing data sheet! o_O
  10. eetech00
    Jun 8, 2013
    676
    116
    yeah...sometimes they put it on the data sheet...
  11. MikeML
    Oct 2, 2009
    5,450
    1,066
    Not anymore...
    All the newly introduced parts have the encrypted models I mentioned...
  12. eetech00
    Jun 8, 2013
    676
    116
    Their not all encrypted....some are unencrypted pspice models...
  13. wayneh
    Sep 9, 2010
    12,368
    3,224
    I'm not sure "encrypted" is the right word. I can read the model files they provide, I just can't figure out how to use them.
