How to implement 315mhz RF wireless into my circuit?
Discussion in 'The Projects Forum' started by ngzongyi, Feb 18, 2015.
  1. ngzongyi
    Feb 18, 2015
    Hi All
    Im new to here.
    I did up a heart rate circuit, and the output is a LED which will blink on very heart beat detected.
    I've gotten myself a pair of 315mhz RF transmitter and receiver.
    Is it possible that I output the circuit to the RF transmitter. then a LED to the receiver on a separate circuit, but will still blink on every heart beat.
    How should i go about doing that?
    ngzongyi
  2. Dodgydave
    Jun 22, 2012
    5,146
    769
    We need a diagram of project,also which RF modles are you using?
  3. ngzongyi
    Feb 18, 2015
    Hi
    Thanks for reply.
    This is the circuit i have built:
    D2 is the photodiode, where a finger will be placed and shone with a LED. The LED at the right end of the circuit is the LED which will blink on every heartbeat detected.
    This is the RF module i have gotten:
    http://www.seeedstudio.com/depot/315Mhz-RF-link-kit-p-76.html
  4. Dodgydave
    Jun 22, 2012
    5,146
    769
    Looking at the modules ,the transmitter has a data input which connects to your Ic2 pin 7, this should be transmitted to the receiver on the output pin which goes high to half the supply voltage and low, it should be in synchronization with your led.
