How to identify various transformers
Discussion in 'General Electronics Chat' started by Gdrumm, Feb 9, 2010.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    Does anyone know of a web site which describes (with photos) and identifies (by number) various transformers?
    Thanks,
    Gary
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There are so many different functions transformers perform, so many manufacturers with their own standards, and so many different sizes in each category that something like what you want seems highly unlikely.
    Have you some specific application in mind?
  3. Gdrumm
    Aug 29, 2008
    684
    36
    For example, what numbering conventions might I find on a transformer that goes to:
    1. An entertainment system amplifier
    2. An automotive battery charger
    3. A microwave oven (high voltage)
    4. A small appliance
    5. Any other household items with transformers
    Thanks,
    Gary
  4. rvh002@gmail.com
    May 15, 2009
    118
    In all the years I have worked with transformers, I have never heard of or seen a convention. Every manufacturer uses his own codes for his own products, that is, if he actually bothers. Quite often there are no codes except a company stock code, typically for microwves etc.
  5. bouncetherabbit
    Oct 25, 2009
    10
    since there is a topic on transformers, can I ask is there any type of isolation transformers that would accept a 50mVp-p sine wave at the primary side? also, the primary side impedence would have to be more than 8ohm.
    Thanks!
  6. Gdrumm
    Aug 29, 2008
    684
    36
    I have Googled and Ebayed, but am coming up dry.
    Do these numbers from two of my transformers represent anything to anyone on this forum? They are both fairly heavy, 5-10 lbs.
    83-830-000 KPS My93
    83-490-000 YWEC -09
    Thanks,
    Gary
  7. retched
    Dec 5, 2009
    5,201
    313
