how to help someone with computer remotely?
Discussion in 'Off-Topic' started by PG1995, Sep 12, 2011.
  1. PG1995
    Thread Starter Active Member
    Apr 15, 2011
    753
    5
    Hi
    I remember that once I saw someone using MSN messenger to help his friend remotely. The person was able to control the distant computer through internet. My cousin is very inexperienced with computers and often needs help even while installing programs. On different occasions I have tried to help her unsuccessfully over the phone. With the intention to help her, I downloaded MSN messenger so that I can use to remotely teach or help her but MSN doesn't have that feature now. Please note that I don't exactly remember even if it was really MSN messenger which I saw someone using or some other software but one thing is sure it was pretty easy to use. Just a matter few clicks. Do you know of any program/messenger which I can use to help her. The program should be simple so that we both can easily use it. I myself not very good at computer. Please help me if possible. Thank you.
    Regards
    PG
  2. Arius007
    Sep 2, 2011
    14
  3. t06afre
    May 11, 2009
    5,939
    1,222
    You have also Real VNC http://www.realvnc.com/ It may cost about 30$. But you can download and trail for 30 days.
  4. PG1995
    Apr 15, 2011
    753
    5
    Thank you very much. I think I have found the right program. TeamViewer would do it.
    Best wishes
    PG
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Logmein (https://secure.logmein.com/) is a very professional solution, and has a free version for non-commercial purposes.
    You, as the technician, create an account and then download the software in every computer you want to control remotely.
    Then, if the computer is on, you can log in to the logmein site and access it fully. With the correct BIOS settings I think you can open it even if it's off.
    This is the software I use to provide technical support to my parents.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    In our office we use webex: http://www.webex.com/
    It is NOT free but works over the internet through firewalls etc.
    Bertus
  7. PG1995
    Apr 15, 2011
    753
    5
    Thank you, GeoRacer, Bertus, for your suggestions.
    Regards
    PG
  8. maxpower097
    Feb 20, 2009
    795
    388
    I second VLC. I've used the free version for monitoring work minions for years.
  9. JoeJester
    Apr 26, 2005
    3,393
    1,211
    msn messenger does have that feature. I've helped many, a decade ago, using it.
  10. ElectroDFW
    Sep 2, 2011
    15
    We use ShowMyPC here. Free, and both sides can be just "Run" without needing to be saved or installed. One side chooses "show" one side chooses "view", and the show-er gives the viewer the randomly generated access code given by the program to access the show-er's PC. Works via TightVNC.
    Now with Windows 7 here, i'm interested in how well Remote Assistance would work for this situation.
    Regards,
    --David M--
    aka Electro
