Hello All,
I made a PCB from 22 mm in diameter (circle) with 2 layers.
On this a frequency of 3 Mhz is made in a self oscillating configuration (and of course all the not wanted harmonics) with 2 FETS in half bridge configuration on 311 V (220V ac * 1,414)
When using the 2 layer PCB the FETS stay cool and temp raise is about 10 Degrees Celsius.
With this configuration I have about 10 dB to high level on signals to pass the tests
To reduce the EMI, I decided to order a 4 layer PCB with ground and VCC as two layers inside the PCB as suggested by many articles. Effect is that the FETS become very hot now (raise is more then 25 degrees).
I redesigned the PCB with 2 internal ground layers 5 mill from top and bottom and 47 mill between the 2 grounds to meet the 63 mill overall thickness.
I see many articles about impedance, length of traces and so on...it becomes too much for me to handle all
My question: 2 ground layers as proposed here will have the same effect as ground and power layer to lower the EMI?
I hope with only 2 ground layers that the FETS will not become so hot anymore, which is my goal
I also redesigned the PCB to add direct VCC and GND traces (on the other layers) to the parts needed and still have the 2 ground layers. Is that a good design? or do I face "bouncing" of signals.
Any advice would be welcome
