how to get negative output pulse from 555
Discussion in 'Homework Help' started by TAKYMOUNIR, Dec 7, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    how to get negative output pulse from 555 timer in monostable state
  2. praondevou
    Jul 9, 2011
    2,936
    489
    From a simple 555 monostable you can't get a negative output. Do you mind telling us what you want to achieve? What is the negative pulse for, what's the pulse width and voltage?
  3. MrChips
    Oct 2, 2009
    12,622
    3,451
    You can get a negative pulse but it would be best for you to elaborate on what you are trying to do.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    This is one way in which it could be done.
    TAKYMOUNIR likes this.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Hi do you mean negated output. Negated means short explained that then the "output" is supposed to be in high state it is in low state and vice versa.
