how to get gain from this datasheet
Discussion in 'General Electronics Chat' started by indianhits, Mar 13, 2010.
  1. indianhits
    Thread Starter Active Member
    Jul 25, 2009
    86
    Hello i have this datasheet of Transistor BC107
    Code ( (Unknown Language)):
    1. http://www.datasheetcatalog.org/datasheet/SEME-LAB/BC107.pdf
    i need this to calculate Ic(collector current)=B x Ib(base current)
    Thanks!!!!
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    In the datasheet β=Hfe=H21e
  3. indianhits
    Jul 25, 2009
    86
    so what is the value of β.Inthe datasheet its showing group-a,b,c what is the value of my β then??? i can't understand
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    BJT are not manufactured with exact beta values; rather, they are specified as meeting a required range or minimum beta value ( group-a,b,c).
    Group A - βmin=110
    B - βmin=180
    C - βmin=380
    Two identical transistors with the same part number could vary by more than 100% in their actual beta values.
    And beta (H21e) also change with collector current Ic.
    for 1 and Ic=2mA the β=250
    The beta β in datasheet is called hfe or H21e
      File size:
      19 KB
      24
      File size:
      45.8 KB
      49
