How to get a single ended output
Discussion in 'General Electronics Chat' started by dumindu89, Jun 6, 2012.
  1. dumindu89
    Oct 28, 2010
    113
    I need to get a single ended output from the MAX2606 VCO IC instead of differential output.
    Can anyone one confirm that the configuration shown in following figure is correct or not?
    If not please let me know the correct configuration.
    MAX2606 datasheet:http://datasheets.maxim-ic.com/en/ds/MAX2605-MAX2609.pdf
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Your circuit diagram does not show R1 and R2 connected to VCC.
    Make sure R1 and R2 are connected to VCC.
    I do not know if R2 is required. You can try omitting R2.
  3. dumindu89
    Oct 28, 2010
    113
    Thanks.
    According to the datasheet, for the differential output the two resistors are used as pull up resistors. What does that mean?
  4. MrChips
    Oct 2, 2009
    12,623
    3,451
    It means that the outputs are open-collector,
    that is, the transistor's collector has not been connected,
    and it has been left up to the designer to provide their own external load.
    This is true regardless of if you use differential or singled-ended output.
    dumindu89 likes this.
  5. dumindu89
    Oct 28, 2010
    113
    Then, I do not need R2 for my purpose.
  6. crutschow
    Mar 14, 2008
    13,472
    3,359
    The differential output stage may need the bias current from both outputs for proper internal bias of the circuit. I would add both resistors even if you take the output from only one.
