I have been wondering lately:
How can I get a negative high voltage output from a flyback transformer?
If I connect the primary in reverse polarity will I get a Negative High Voltage?
What about the diodes in the flyback secondary, will they prevent the negative voltage?
(My thinking is, diodes only block current flow so a negative HV could be produced simply by reversing the primaries polarity, without having to remove the diodes, am I right?)
