Crutschow, how can i send you a pm??It's simple as Dodgydave showed, if you don't need a 50% output signal duty-cycle.
The 4000 series is CMOS architecture.I need it with cmos
Sorry, I don't normally do pm's.Crutschow, how can i send you a pm??
Could you clarify what you mean by 8/9? I interpreted it to mean that for every 9 input clock pulses, you wanted 8 out.Hello
I build freq divider 8/12 using d flip flop, but I wonder how to make it 8/9 ?
I build my divider like:
%2/3 --> %2 ----> %2
the result is 8/12, now how can I play with gates to obtain 8/9 instead?
thanks a lot
If you've built it then you must have a schematic on hand which you could post to clear up what you mean.Hello
thanks a lot
8 isn't hard at all - there are old logic family databook on archive.org - there are probably application examples how to hook up standard divider stages for weird and wonderful ratios.Hello
thanks a lot
Start by multiplying your clock by 8. Or, in actuality by 2. There is a common circuit using digital logic to multiply by 2. Just apply this circuit three times to multiply by 8 (2^3=8).Ok , but I need the circuit configuration...
I deleted my original post. It didnt make sense (I must have been drinking). My updated response is below.
First, is the frequency you are "multiplying" by 8/9 a digital or analog signal?
If digital, read on...
Then feed the multiplied signal into a CD4017. Take output 9 and connect it to reset. Take any other output as your divide by 9 output.
This results in an 8/9 signal.
Thread starter | Similar threads | Forum | Replies | Date |
M | Increase +30% the freq of the signal | Analog & Mixed-Signal Design | 18 | |
Any affordable freq analyzers out there? | Test & Measurement | 19 | ||
G | Value of transfer function at the corner freq. | Homework Help | 12 | |
changing transmit freq | General Electronics Chat | 4 | ||
T | Flip Flop Freq Divider | General Electronics Chat | 8 |
