Absolutely! Thank you!That is a very good question which I cannot answer until the circuit is built and tested.
I'm only presenting ideas for you to work with. Remember this is your homework, not mine.
Thank you! I will now simulate your suggestion...will take a while to play with...This might be a possible solution.View attachment 75125
That was my first idea, however, I have little to no expierence with TA.... will keep the idea for later use!I've never thought of this one before but I would start thinking about a transconductance amplifier.
Start by thinking about Ohm's Law.
I = V/R
If you can keep V constant but change R as a of function V
then I = k/V
Now it is relatively easy to convert I to an output voltage.
Yes, Vi is always positive. Thank you!A two op-amp solution possibly....???
Dear t_n_k,A two op-amp solution possibly....???
Naturally.... thanks... the circuit appears to me a basic Log-amp (first op-amp), which is inverting as well. The second should be anti-log, if I am not mistaken. Thus, in terms of functions, we have LOG-Invert-Anti-LOG, right? But why you used differential amplifier (for a reason, which is?).Yes - the arrangement is somewhat basic biasing of Q1 & Q2 to preset Iref. Perhaps a constant current source might improve accuracy / linearity.
Keep in mind this idea is purely a thought experiment on my part. I've neither built nor simulated the circuit. Make of it what you may.
by Aaron Carman
by Duane Benson
by Aaron Carman
