how to generate a signal of 500 MHZ signal?
Discussion in 'Wireless & RF Design' started by yasaswini, Feb 16, 2016.
  1. yasaswini
    Feb 15, 2016
    how to generate any signal which is of atleast 500MHZ using transistors ?
    please help me..
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What kind 500 MHz. signal? I'd consider Mini-Circuits if I were you.
  4. yasaswini
    Feb 15, 2016
    If it is not possible only with transistor is it possible by using IC's too?
  5. yasaswini
    Feb 15, 2016
    what will happen if....
    I use a normal signal generator circuit by simply changing the values of tank circuit by using F=1/(2*pi*(SQR RT (L*C)))
    does this work..
    EX:
    L=22nH
    c=1pF
    then im getting F more than 500MHZ
  6. kyka
    Jun 7, 2015
    23
    It's not so simple for such high frequencies. You are almost on the boundary between RF and Microwave. These signals are usually the output of a voltage multiplier fed from a stable source (e.g. PLL). So before we say anything else, you should tell us if you want to actually implement this signal generator or construct it in a simulator.
  7. DickCappels
    Aug 21, 2008
    2,768
    669
    I think the circuit below would meet the most liberal interpretation of "how to generate any signal which is of atleast 500MHZ using transistors ?" Note that you would need some inductance and capacitance at the very least. The circuit below has been in daily use out-of-doors as an RF remote control transmitter for the last 7 years and has not had the oscillation frequency adjusted since the initial adjustment. The receiver is regenerative.
    I've pushed this circuit to past 500 MHz (the limit of my ability to determine frequency) by reducing the inductance of the loop and reducing the tuning capacitance.
    And it can be crudely made and still work as in the photo below, where the resonant loop was cut with a drill equipped with a router bit.
    Willen and Kermit2 like this.
