How to generate a Modified sin wave...?
Audioguru
Joined Dec 20, 2007
11,248
If you use a DC to DC converter to make a high voltage then it can operate at a high frequency and use a small lightweight ferrite core transformer. The PWM circuit that makes the sine-wave can also use the same high frequency.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
OK, i have no idea of F. core transformer..
so, please tell while buying it what to kept in mind for handling at least 500Watt load??
Audioguru
Joined Dec 20, 2007
11,248
A 500W ferrite core transformer is custom-made for a manufacturer who makes a pure sine-wave inverter. You can buy the inverter then take it apart to see how it is made, maybe the manufacturer will give you the schematic.
Papabravo
Joined Feb 24, 2006
21,228
I haven't got a clue about what your schematic and symbols mean. If you want people to understand what you are doing you have to produce a readable schematic with standard symbols not some scribbled "chicken scratchings". If you can't do a schematic with a computer then at least get some symbol templates and produce a hand drawn one of a suitable size and legibility.
I see what looks like a "half a transformer" producing 220VAC. This seems unlikely in my view.
absf
Joined Dec 29, 2010
1,968
The resolution of your schematic is too low. When I cropped and enlarged it I can't even know which mcu you're using.
Why dont you you do a Shift/Print Screen, copy paste the picture on "Paint", then save it as a "PNG" file and then post it here. I do that many times with my proteus schematics and it worked very well.
My internet browser also have a screen capture icon on the tool bar....
If we cant see your circuit, how can we help you?
Allen
i have though of an idea of producing a sinewave from sg3524.
1)pass the two outputs of sg3524 thru a low pass and twin tee(notch) filters these outputs would approximate sine.
2)pass these approximate sinewave into class D amplifier and we should have a pure sinewave
Please give this idea a thought and reply
