How to generate a clock pulse?
Discussion in 'General Electronics Chat' started by alexlesuper, May 9, 2011.
  1. alexlesuper
    May 9, 2011
    Hello forum,
    I am new to electronics and for my first project I have decided to build an ADC. I am using the design found on this very site: http://www.allaboutcircuits.com/vol_4/chpt_13/7.html
    To complete this, I need to use a clock pulse to drive the counter. However, I am not sure how to generate such a clock pulse. For now I am simply using an arduino and hard coded a digital signal that goes up and down. However, when I am going to solder everything in, I will need something else to generate the clock pulse. I looked around on digikey and googled a bit, but I am a bit confused as to what I really need. Do I need a crystal oscillator? What is ideal in my situation?
    Thanks in advance for the help. :)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. nbw
    Member
    May 8, 2011
    36
    10
    A simple 555 astable?That may or may not be accurate enough. There are a bunch of options out there :)
  4. magnet18
    Dec 22, 2010
    1,232
    125
    This is extremely accurate.
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
    I don't think he wants a 1Hz clock. The U/D counter in his ADC circuit would then be so slow it would never be able to keep up with even a slow moving input signal.
    I also don't believe clock stability matters either (within reason anyhow). All its affecting is slight changes in compare time which is insignificant for what he's doing.
    A 555 is cheap, pretty stable and also very adjustable which would allow him to see exactly how clock speed affects a counting ADC.
  6. magnet18
    Dec 22, 2010
    1,232
    125
    If the OP does go with the 4060 then there are multiple signal outputs at various frequencies, and it can be changed by changing the capacitor values.
    But if accuracy is irrelevant a 555 is probably the way to go.
  7. nbw
    Member
    May 8, 2011
    36
    10
    You could give it a try with a 555 to test the rest of the circuit; as mentioned thougha 4060 circuit with a crystal (rather than oscillator) tapped off at an appropriate output would give you a very accurate timebase.
  8. radiohead
    May 28, 2009
    474
    31
    the Unijunction transistor excellent for generating pulses when used in a relaxation oscillator.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The OP has left the building.
