How to generate 0 to 12 adc voltage
Discussion in 'General Electronics Chat' started by jobycm, Dec 18, 2014.
  1. jobycm
    Nov 17, 2011
    22
    I wanted to generate a linearly variable voltage ranging from 0 to 12 volt similar to normal adc (0 to 5 v). My purpose is to upgrade my (0 to 5v) adc to a (0 to 12v) system. Please help me with this.
    Thanking you..
  2. ericgibbs
    Jan 29, 2010
    2,585
    389
    hi,
    Are you asking for a 0 to +12V ramp voltage generator
    or
    an OPA amplifier to condition an existing 0 to +5V ramp signal to 0 to +12V?
    or
    both.:)
    E
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I suggest using an amplifier with a gain of 2.4.
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    A 12V supply and a linear potentiometer across it?
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    I don't know what you are after, but if you employ a generic op amp without using the proper techniques your precision will decrease.
  6. crutschow
    Mar 14, 2008
    13,475
    3,362
    Exactly what are you going to do with the 12V?
  7. jobycm
    Nov 17, 2011
    22
    An op amp amplifier with 2.4 gain sounds feasible. My existing setup is a variable voltage out which varies between 0 to 5v, I want a ratio circuitry setup so that i could use this (0 to 5v) as input to the circuit to generate a 0 to 12v output.
    Thanking you...
  8. jobycm
    Nov 17, 2011
    22
    The variable voltage out (0 to 12v) is to be used simply as some sensor input.
    Do you guys know if there is a DAC or a digital potentiometer which could generate or source a 12 volt variable voltage??
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is a circuit. It requires a +15V single supply if you use a LM324 or LM358. These work with their inputs at or slightly below Vss (0V), and their outputs pull close to (but not all the way to) Vss. Otherwise you will need split supplies to get to zero output... 103.gif
  10. jobycm
    Nov 17, 2011
    22
    Thank you guys...
