how to free the memory?
Discussion in 'Programmer's Corner' started by summeranson, Sep 24, 2009.
  1. summeranson
    Feb 12, 2009
    28
    What should you do to free the memory after running this code?
    char *a; a = new char[20];
    A. I don't know
    B. delete [] a;
    C. delete a[];
    D. delete a;
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Shouldn't this be in the homework section?
  3. Mark44
    Nov 26, 2007
    626
    Are you using a textbook? If so, look at the section on the various forms of delete that are associated with new.
  4. dushuai
    Sep 9, 2009
    10
    delete is associated with new,and a is an point array,so you should use delete a to delete the point array
