How to Format computer.
Discussion in 'Computing and Networks' started by RRITESH KAKKAR, Oct 26, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I have never format computer to drive O.S. IN IT.
    please tell for window 7 and XP
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    You mean format the hard drive?
  3. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Do you have Win7/XP on external media, or only in a hidden partition?
  4. takao21203
    Apr 28, 2012
    3,578
    463
    Nonsense post.
    You put the dvd, then follow instructions.
    Not work, then better throw away.
    James Britton, #12 and DerStrom8 like this.
  5. vead
    Nov 24, 2011
    621
    8
    1. Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc and then shut down your computer.
    2. Restart your computer.
    3. Press any key when prompted, and then follow the instructions that appear.
  6. joeyd999
    Jun 6, 2011
    2,757
    2,931
    You're Microsoft tech support, aren't you? :D
  7. vead
    Nov 24, 2011
    621
    8
    I use windows os . many time I have formatted my pc
  8. joeyd999
    Jun 6, 2011
    2,757
    2,931
    Ok. I just noticed you were from India, and the last time I called MSTS, one of your countrymen told me exactly the same thing.
  9. dl324
    Mar 30, 2015
    3,377
    651
    Formatting applies to some forms of data storage. A PC is a conglomeration of components; most of which can't be "formatted".
  10. ian field
    Oct 27, 2012
    4,447
    791
    When my W10 upgrade on top of W7 went tits-up, it wouldn't repair and refused to do a clean install either.
    In the end, I used Acronis utils to delete the partition and installed Linux Mint to overwrite everything.
    Deleting the Mint partitions was even more fun, I had to use the Acronis add drive util, but was then able to do a clean, ground-up install of W10.
    Whenever the PC has that much upheaval - its time to implement a boot drive for the OS and another drive for storing everything else.
    When it became obvious that I'd have to clean the boot drive, I just unplugged all the other drives with my files on them until the PC was back up and running again.
  11. joeyd999
    Jun 6, 2011
    2,757
    2,931
    Actually, there are few things in life easier. Really.
  12. ian field
    Oct 27, 2012
    4,447
    791
    I used the first thing that worked - and Acronis mount disk wasn't the first thing I tried.................
  13. BReeves
    Member
    Nov 24, 2012
    412
    64
    I still use an old DOS program I found some time ago called "Overkill". When ran from a boot CD it will return any hard drive to an as-shipped state ready to partition and format. Just don't try to run it off a boot USB drive, it will kill the USB drive, also make sure only 1 hard drive is installed in the computer.
  14. MrAl
    Jun 17, 2014
    2,556
    515
    When i used XP i dont remember having to reformat the drive ever. Just a reinstall now and then.
  15. ian field
    Oct 27, 2012
    4,447
    791
    All I can find on that search is gaming software.
    As I put the OS on one HDD and everything else on another - that would be perfect for me.
    Its a long time since I played with any DOS utils - how do you make a DOS boot CD?
  16. BReeves
    Member
    Nov 24, 2012
    412
    64
    Give me a little time to decide the best way to get you the files and I will make it easy for you. In the interim search for and download Magic ISO.
    Better yet, download and make yourself a boot cd from this web site.
    http://www.ultimatebootcd.com/
    It will have hard drive utilities that will get you where you need plus several other useful utilities for Windows.
    I buy allot of computers for Kiosks and have to change the OS to Windows embedded. Booting to a DOS CD and running overkill is allot faster than using the UBCD but it is dangerous.
  17. ian field
    Oct 27, 2012
    4,447
    791
    Can't see the wood for the trees on the UBCD download site.
    Its so cluttered with adverts I can't find the download link.
  18. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    I use Dos 7.1 .ISO for that, I think it is still available out there, it has extra features such as unlimited file name length etc, It is not sanctioned by Windows, but I believe ripped from Win 98/XP.
    Max.
  19. Ramussons
    May 3, 2013
    562
    92
    Get Gparted ISO from a Linux site.
    Load it on a Penstick or a CD
    Boot off that and you can do Format / Partition / Copy ....... your Hard Disk
