How to Flash two 240 volt bulbs alternatively
Discussion in 'General Electronics Chat' started by jmarshal84, Sep 28, 2016.
  1. jmarshal84
    Sep 28, 2016
    Hi all,
    I'm very new to electronics,
    i want to flash two 240 volt bulbs alternatively , how to do this can any one help me to build a circuit for this.
    Best Regards
    Marshal
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Welcome to AAC!
    Your requirements are a bit vague. A SPDT switch could do it but, since you're asking for a circuit, your requirements must be more complicated.
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    Welcome to AAC.
    In order to avoid playing the game of 101 Questions and Answers, you do need to be more up front about what you are doing.
    What is the power rating of the light bulbs? We are to assume these are 240VAC bulbs?
    What is the duration that one bulb will be lit before alternating to the other bulb?
    Why are you doing this?
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    Wig Wag
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Incandescent, CFL or LED bulbs?
  6. jmarshal84
    Sep 28, 2016
    Hi
    Thank u for ur reply
    My requirement is very simple like flashing two led bulbs using 555 timer ic, instead of led I want to use 240 volt bulbs
  7. dl324
    Mar 30, 2015
    3,376
    651
    SPDT relay:
  8. crutschow
    Mar 14, 2008
    13,478
    3,365
    Probably the easiest way while still being safe is to directly drive a pair of solid state relays from the 555.
    Depending on how frequently and length of time you want the lights to flash a mechanical relay may not have adequate reliability.
  9. #12
    Nov 30, 2010
    16,665
    7,310
    Still playing 20 questions. I would say that I have seen relays rated at 100,000 operations and higher, but we have no information on how many alternations per minute or whether this will be a 5 minute display or a permanent installation.
  10. GopherT
    Nov 23, 2012
    6,303
    4,026
    Or one part of a bigger project.
    "... and I want them to flash alternately every time my girlfriend pops out of a giant cake at half-time..."
