I don't. But I know how to import *.lib file and *.idx file.Do you know how to import generic new Spice models into Proteus which claims to be Berkely Spice compatible? There are 555 models available which work with PSpice or LTSpice.
no capacitor leakage.Did you diddle with the leakage on capacitors or something that would cause such current flow?
If not, it looks like you managed to let the Magic Smoke out of a virtual 555 timer.
Yes, failures increase if the user doesn't wear their virtual anti-static wristband.Maybe the Proteus simulator is so good that it generates random failures of ICs just to keep you on your toes...
http://www.youspice.com/ys/howtoimportpspicemodelsintoproteus.3sp?pageNum=0 Is this the way to do it?Do you know how to import generic new Spice models into Proteus which claims to be Berkely Spice compatible? There are 555 models available which work with PSpice or LTSpice.
