How to find the resistor value ?
Discussion in 'Homework Help' started by Lee Pierre, Dec 21, 2015.
  1. Lee Pierre
    Dec 13, 2015
    Temperature sensor produces an output
    Vs= (43.2mv)T'C + 750mv
    This express in term of temperature versus sensor voltage (vs)
    T=(vs-0.75)/0.0432'C
    To design using combination of inverting, non inverting and summing amplifier togather with 1V reference voltage source .
    The sensor voltage Vs and 1v ref source Vref are two input signal of the circuit.Design circuit should produce an output voltage Vo to indicate the temperatureaccording to equation Vo= T/10.('C/10)
    When T=0'C , Vo =0v
    T=100'C , Vo = 10v .
  2. Lee Pierre
    Dec 13, 2015
    Base on this can we get the resistor value for the amplifier using?
  3. WBahn
    Mar 31, 2012
    18,079
    4,917
    What resistor value? You need to first get a circuit topology that you think will work. There's no point talking about unspecified resistors in unspecified circuits.
