Thanks for the heads up. I'm pretty sure the center is negative.Before you connect the TRS connector make sure you measured correctly.
In order to make one out of a 24V supply by adding to voltage regulators, were you thinking of putting those inside the power supply or making a separate box to do the regulating?A dual 12V power supply you could make out of a 24V power supply. There are also plenty of small dual power supplies on the market, even though the stable regulated power supplies are not the cheapest, so maybe you buy an unregulated with a higher voltage and put two voltage regulators at the output.
Do you have any suggestions for places to look for a dual power supply? Most of the supplies I have found are open frame or really large stand alone units. I haven't seen any in a portable or "wall wart" form. If you have any suggestions, I'm all ears!
OK, good to know!Yeh, I think we were splitting hairs here. There's only 3V difference between 9V and 12V. In this particular circuit I think 12V would do no harm.
Very good point! If only this thing could talk!Not really. We don't know the history in the product development. It is not unusual to change design specs after the board was printed.
