I have to set breakpoints to examine memory and register for the following code. Could anyone teach me how to find the breakpoints and what should be set as "add SFR" and "add Symbol"? Thank you.
Code:
; File CHASER.ASM
; Blinks LEDs on outputs (Port B) in a rotating pattern.
; Reverses direction if port A, Bit 0, is high.
processor 16f84
include <p16f84.inc>
__config _RC_OSC & _WDT_OFF & _PWRTE_ON
; Give names to 2 memory locations (registers)
J equ H'1F' ; J = address hex 1F
K equ H'1E' ; K = address hex 1E
; Program
org 0 ; start at address 0
; Set Port B to output and initialize it.
movlw B'00000000' ; w := binary 00000000
tris PORTB ; copy w to port B control reg
movlw B'00000001' ; w := binary 00000001
movwf PORTB ; copy w to port B itself
bcf STATUS,C ; clear the carry bit
; Main loop. Check Port A, Bit 0, and rotate either left
; or right through the carry register.
mloop:
btfss PORTA,0 ; skip next instruction if bit=1
goto m1
rlf PORTB,f ; rotate port B bits to left
goto m2
m1:
rrf PORTB,f ; rotate port B bits to right
m2:
; Waste some time by executing nested loops
movlw D'50' ; w := 50 decimal
movwf J ; J := w
jloop: movwf K ; K := w
kloop: decfsz K,f ; K := K-1, skip next if zero
goto kloop
decfsz J,f ; J := J-1, skip next if zero
goto jloop
goto mloop ; do it all again
end ; program ends here
Code:
; File CHASER.ASM
processor 16f84
; Program
mloop:
goto m1
goto m2
m1:
m2:
movwf J ; J := w
goto kloop
goto jloop
