I am looking for a small transformer with a 1:30 turn ratio. I have found a nice selection of transformers, with the datasheet as follows:
http://www.bourns.com/data/global/pdfs/SRF0703.pdf
The problem is, it doesn't appear to list the turns in each coil. I could calculate the turn ratio from the inductance of each coil, but they only give the parallel inductance and series inductance of the two coils.
How would I go about figuring out the turn ratio using the information from that datasheet? Thanks!
