How to find Median
Discussion in 'Math' started by RRITESH KAKKAR, Dec 30, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Q. Find the median of the given data: 13, 16, 12, 14, 19, 12, 14, 13, 14.
    According to method
    To find the median, the data should be arranged in order from least to greatest. If there is an even number of items in the data set, then the median is found by taking the mean (average) of the two middlemost numbers.
    12,12,13,13,14,16,19
    But these number are common how to solve?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    gives the center element in the sorted version of list, or the average of the two center elements if list is of even length.
  4. Ramussons
    May 3, 2013
    562
    92
  5. anhnha
    Apr 19, 2012
    776
    48
    To find the median number: Put all the numbers in numerical order. If there is an odd number of results, the median is the middle number. If there is an even number of results, the median will be the mean of the two central numbers.
    Q:
    find the median of the given data: 13, 16, 12, 14, 19, 12, 14, 13, 14.
    A:
    Step 1: arrange these numbers in order from least to greatest:
    12, 12, 13, 13, 14, 14, 14, 16, 19
    Step 2: there is an odd number of items (9 numbers here) so the median is the middle number (it is the fifth number here).
    Median = 14
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Why we find median what is it purpose in life?
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What percentage should be added to 40 to make it 50?
    Ans 25
    How?
    let
    40+x=50
    x=10?????
  8. anhnha
    Apr 19, 2012
    776
    48
    I know one is median filter to reduce noise in images. However, I believe it is used a lot in in other fields.
    https://en.wikipedia.org/wiki/Median_filter
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Which is the smallest fraction among the following?
    3/4=0.75
    2/3=0.6666
    why answer is 3/4 ?
    it should be 2/3..
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  11. anhnha
    Apr 19, 2012
    776
    48
    I think percentage here is "percentage of 40". So it will be 40 + x*40 = 50 or x = 0.25 or 25%.
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    @RRITESH KAKKAR ,
    Stick to ONE question in ONE thread.
    Now you are taking a second question in this thread.
    Bertus
