How to find its 100%?
Discussion in 'Math' started by Lightfire, Dec 15, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    For example I received an examination scored 77 and its equivalent in percentage is 90%. How to find it's 100% value?
    For example it is something like 77 / 84 (just example)
    Pls. sorry for bad explanation.:)
    Lightfire
  2. mrmount
    Dec 5, 2007
    59
    7
    (77*100/90) = 85.556. I believe you are asking 90% of what value will give you 77.
    Lightfire likes this.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Simple method of three:
    X=unknown percentage.
    C=your current score
    T=the best score for the specific test
    X=C/T*100 (in %)
    If you know your percentage in the test, and you know the percentage of the test in the total grade, then your contribution to your total grade is
    X=final contribution
    T=test contribution
    S=your score in the test in percentage
    X=T*S
    Does that help?
  4. Lightfire
    Oct 5, 2010
    690
    21
    I don't get. What I am looking is the total score.. pls hep.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Can you try to explain what you have and what you want a bit better? I don't understand what you want to achieve.
  6. Lightfire
    Oct 5, 2010
    690
    21
    Um,
    For example, the percentage is 75% and its value is 3.. So how to know the denominator of the 3? In this case, its 4...\frac{3}{4}=75%
    MMMM, the denominator now is missing,,,<br><br>\frac{77}{?}=90%
    plllllllllllllllllllllllls help....
  7. lopoditi
    Jul 24, 2011
    6
    77/0.9
    simple
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    0.9=\frac{77}{max score}
    Divide 77 by .9
    and about 85.5 (?!) points were available, if 77 points correct gave you 90%
  9. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    <br />
<br />
\frac{77}{?}=90%\ \ \rightarrow\ \ \frac{77}{90%}=?<br />
\ <br />
\ <br />
Does\ this\ help?<br />
<br />
