how to find inductor value on fr formula?
Discussion in 'Homework Help' started by kee23, Sep 20, 2012.
  1. kee23
    Feb 1, 2012
    10
    on the question it says i need to find a resistor and inductor values if i have
    fr= 10.7Mhz Capacitance=0.1nF BW=200kHz
    I was guessing that I can use the frequency resonance formulas and after that, i don't know to simply it to find Inductor value.
    Can someone show me the steps to simplify on the formulas? or am i thinking it wrong?
    Thanks.
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    Do you know the equation for resonant frequency? If you knew it, could you use algebra to manipulate the equation and solve it for a variable? Is your filter supposed to be passive; that is without any electronic amplification?
  3. kee23
    Feb 1, 2012
    10
    it's an active filter, but not much need to worry. and formula should be 1/2pi square root LC that's what i meant, i don't seem to know how to do it
    answer for inductor is 2.27uH
  4. t_n_k
    Mar 6, 2009
    5,448
    783
     f_r=\frac{1}{2\pi \sqrt{LC}}
     {f_r}^2=\frac{1}{4\pi^2 LC}
    Now make L the subject of the equation.
    Presumably this is a series LC circuit - otherwise you must apply the parallel case equation - which in your case would require the concurrent solution for the R value as part of the exercise.
  5. Dodgydave
    Jun 22, 2012
    5,167
    777
    2.2uH
    Calculator for resonance
    http://www.1728.org/resfreq.htm
