@WBahn Sorry for that. I just thought it will help him to get things straight. Won't happen again.This is the Homework Help forum, not the Homework Done For You forum.
Please do NOT just do the poster's assignment for them -- in most cases it does them little good in terms of learning the material.
You intentions were laudable, but all you really do is make it easy for someone to claim credit for work they did not do while not understanding anything any better.@Bertrus
Thanks for pointing it out. Can I post a link to a site containing relevant theories ?
Sorry for my mistake. I was browsing on the same question and most probably for the same home work. So I just hoped to make it easy for him to understand.
What material do you have that is part of this course? What text are you using?I don't understand the following things related to the question.
1) What is the reference voltage of DAC's (n bit R/2R).
2) How to find the number of bits in this DAC.
3) how to set reference voltage of ADC by using a DAC.
I tired find theories related abouve questions and found nothing. So I could not do anything to solve these.
Yes. Are from galle center?@thar07 By the way are you a student of OUSL?
I refer "The 8051 Microcontroller and Embedded systems" book as the material.What material do you have that is part of this course? What text are you using?
What have you learned about DACs and ADCs in general?
Yes, but it helps to get the basic knowledge about these.@thar07 Nope. I'm from Matara center. But I live in galle. I don't think "The 8051 Microcontroller and Embedded systems" gives much about these.
How should WE know? It's YOUR assignment!Do I have to display a decimal value or a binary value on the displays?
So same questions. What makes sense to YOU?Assignment doesn't say anything explicitly on what should I display. Thats why i'm confused. And I'm only having a 8 bit ADC.
No, If I got anything I will let you know@thar07 Hello, did you got anything on this topic which can help both of us in getting this assignment done?
Thanks. By the way great know some one from galle studying in OU. What is your field?No, If I got anything I will let you know
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jake Hertz
