How to find angle...
Discussion in 'Math' started by RRITESH KAKKAR, Dec 30, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    A clock shows the time as 12.20. What is the angle the hour hand makes with the minutes hand?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    It depends if you want to compensate for the hour hand, as it shifts a tiny bit every second.
    That is how a mechanical clock works.
    The minute hand makes 6 degrees every minute.
    Bertus
    RRITESH KAKKAR likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    But it is wrong answer
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    6sec*5min*4=120 wrong
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    In a mechanical clock, the hour hand moves with 1/60 of the speed of the minute hand.
    Bertus
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The question is exactly what is the Angle now..
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I made a mistake in post #5.
    When the hour hand makes a 30 degrees move in an hour, it will make a move of 10 degrees in 20 minutes.
    Bertus
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How?
    There is total 360 if anything go circle/round ...
    the answer is 110 degree why?
  9. hexreader
    Apr 16, 2011
    250
    82
    Draw the analogue clock on a sheet of paper, but instead of the 12 hours, mark the 12 divisions in degrees, starting with 0 degrees at the top.
    The answer should become obvious if you remember to think carefully.
    Hint - the hour hand does not point to 0 degrees
    Over to you....
  10. Ramussons
    May 3, 2013
    562
    92
    The hour hand goes 360 degrees in 12 hours => 30 degrees /hour => 10 degrees in 20 minutes.
    The minute hand does 360 degrees in 60 minutes => 120 degrees in 20 minutes.
    => angle between the hands = (120 - 10) = 110 degrees.
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Here is The Clock
  12. hexreader
    Apr 16, 2011
    250
    82
    That is a good start, but now draw it with the hour hand in the correct place...
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How?
  14. hexreader
    Apr 16, 2011
    250
    82
    Look at a real analogue clock and see where the hands are at 12:20. Think about why the hands are where they are. Draw what you see and then work out the angle between hands.
    Play around with an analogue clock for a while adjusting the time manually and think about what is happening.
    Can't think what else to suggest.
  15. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The Smaller hour hand goes to Top 12hour
    The bigger is at 4 because it is 20 min
    The right angle i.e. 12 hour hand and 15 min is 90 degree , plus more 5 min
    What else to do with it?
  16. hexreader
    Apr 16, 2011
    250
    82
    The Smaller hour hand goes to Top 12hour - wrong - go and find a real clock and study it
    The bigger is at 4 because it is 20 min - correct
    Study a real clock and then try again
  17. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Ok, i got it the 12 will move move towards 4/20min
    it is making 8degree per min why?
  19. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  20. hexreader
    Apr 16, 2011
    250
    82
    Sorry, but I must give in at this point.
    This is just too painful. :(
    shortbus likes this.
