How to find a unknown resistor value in paralell-
Discussion in 'Homework Help' started by ESPguitar, Aug 21, 2005.
  1. ESPguitar
    May 15, 2005
    16
    Long time since i've been here:)
    I need some help with a calculation..
    I have a resistor in a circuit, it's 30 Ω , i wan't to make that to a paralell resistor with total value 20 Ω ..
    How do i find the unknown resistor value?
    Thanks,
    Robin :)
  2. Gorgon
    Aug 14, 2005
    113
    Hi Robin,
    The formula for the resistance(z) of two parallel resistors( a & b ) is z=a*b/( a+b )
    Solving this on a gives you a=z*b/(b-z) (You then put in z=20 and b=30).
    TOK ;)
  3. ESPguitar
    May 15, 2005
    16
    So this gives me:
    I guess this is what you meant:
    A= R2
    B= R1 (we know it's resistance, 30 Ω )
    Z= Rtot (we know the resistance we wan't the paralell circuit to give us, 20 Ω )
    R2=Rtot*R1/(R1-Rtot)
    So:
    R2=20 Ω *30 Ω /(30 Ω - 20 Ω )
    =60 Ω
    R2=60 Ω
    But i guess that it have to be a more complicated formula for this?
    Exactly like it is a easier way to calculate the total resistance in a paralell circuit with only two known resistor values..
    Rtot= R1+R2/R1*R2
    But if we want to find the total resistance in a paralell circuit with 3 or more resistors we use this formula:
    The resistors value is: R1= 10 Ω , R2= 15 Ω , R3= 20 Ω .
    We choose the voltage to have the same value as the resistor with the highest value in the paralell circuit, the voltage will then be 20 volts.
    I=U/R
    I1=U/R1
    20/20=1A,
    I2=U/R2
    20/15=1,33A,
    I3=U/R3
    20/10=2A
    Itot = I1+I2+I3
    1A+1,33A+2A=4,33A
    R=U/I
    Rtot=U/tot
    20/4,33=4,61 Ω
    The total resistance in the paralell circuit is 4,61 Ω.
    Is there a similiar way to calculate the unknown resistor? Or is it nenessecary to use more than 2 resistor in a paralell circuit at any times?
    Thanks for the help!
    Robin :) ;)
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Generally, for resistors in parallel:
    1/Rtot = 1/R1 + 1/R2 + 1/R3 ........
    For many resistors in paralle this is a far easier equation to work with.
  5. ESPguitar
    May 15, 2005
    16
    Ok!
    Thanks for your time and help:)
    Robin
