How to feedback the class D?
Discussion in 'The Projects Forum' started by catherine, May 15, 2007.
  1. catherine
    May 15, 2007
    For a Class D PWM audio amplifier (differential stage and power stage), what is the easiest feedback scheme?
    Since the output of the power stage is a modulated pulse waveform, where should I feed this into?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. catherine
    May 15, 2007
    you are so kind! thanks a lot!
  4. hgmjr
    Jan 28, 2005
    9,030
    214
  5. catherine
    May 15, 2007
    I have paste the main architecture in attach file, please help me!
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    It almost appears as though the first stage is set up as a Delta-sigma converter.
    The design looks like it is a mix of PWM and Delta-sigma.
    hgmjr
  7. Distort10n
    Dec 25, 2006
    429
    Well, for first and last questions:
    1) Yes, you can but if you neglected to use Rf then you would have unity gain.
    4) I think filterless Class D amps ultilize the speaker inductance to help filter rather than using external bulk caps.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings catherine,
    I fixed the link in my earlier reply. The article has some pretty interesting information in it.
    hgmjr
  9. DrNick
    Dec 13, 2006
    110
    look up cherry-hoopers, they may help with your feedback loop from your Full bridge
