Try integration by parts. http://www.slideshare.net/empoweringminds/integration-by-parts-tutorial-example-calculus-2How to evaluate this integral?
Notice that 3x^2 is the derivative of x^3. That should give you a clue to the easy way to solve this one.
So the integral is just exp(x^3)?Notice that 3x^2 is the derivative of x^3. That should give you a clue to the easy way to solve this one.
Would integration by substitution be better?heathhosty,
Ratch
Not quite. Watch out for the negative signs. You said it right above - "substitution". In particular, use \(u=-x^3\) which implies \( du=-3x^2 dx\).So the integral is just exp(x^3)?
Much better as it is a simpler technique to apply than integration by parts.Would integration by substitution be better?
Plus a constant...Not quite. Watch out for the negative signs. You said it right above - "substitution". In particular, use \(u=-x^3\) which implies \( du=-3x^2 dx\).
\( \int 3x^2e^{-x^3}dx=-\int e^u du=-e^u=-e^{-x^3} \)
Yes, indeed. I did not look at the problem close enough, and gave you bad advice. Substitution is the way to go on this one.Would integration by substitution be better?
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
