Hi all.
I need a little help, i am building a water vac suction pump, to empty water from a pond, this is how i want it to work -
1 Suction hose is placed into the water.
2 Pump is switched on manually
3 pump sucks up water into a sump,
4 When water rises to top of sump, it lifts a Float switch and the pump motor turns off.
5 Simultaneously, a solenoid drain valve opens.
6 Sump starts to drain out.
7 When sump is empty, another float switch at the bottom of the sump energizes, closes the solenoid valve and restarts the pump cycling over and over again.
The pump motor is 240 volt AC.
Can anyone help with a circuit diagram please.
Regards
Ray
Regards
Ray
