I have a camera (HackHD) that needs a momentary switch pressed to turn on (>60ms, but <1000ms). The switch simply grounds Pin 3. The camera will be connected to a timer so it turns on once a day. I need to duplicate the momentary switch via the timer to activate the recording.
So I have 12v SLA into the timer. Out of the timer I have + and - into the coil of a DPDT relay. And that is where I'm stuck. Seems like it should be simple, but I'm not getting it.
I found a automotive relay that seems to be what I need using a cap and resister, but I need to convert this to my relay:
Thank you.
Thank you.
