Hi everyone
I'm new to the the forum and to electronics in general, I am used to deal with computers but when it comes to single electronic components I am almost completely ignorant..
That said, the problem I'm facing now is:
I have a few server fans rated 12V and 3.24A, I need them to run at around 8V and 10V (no matter to be accurate, any voltage within this range should be fine), I have a lot of resistors, and about 20 wirewound ones rated 7W and 10W, but since I also have around a hundred of various diodes, I was wondering if it was possible to use them (if necessary i will post the codes, but it's gonna be a quite long list) instead of the resistors to have a more efficient voltage drop.
So, ideally, which diode would I need to drop 2/4V in a fan rated 12V and 3.24A?
