Thanks for that. So what you are saying is that I can reduce the duty cycle to say about 10 or 20% and increase the current through the IR LED in order to achieve distance, am i understanding this correctly? Could somebody explain to me the relationship between duty cycle and mA through the IR LED please. I do understand the shorter "on period" of the LED enables a higher current to pass through it without causing damage,however, is there a formula for this, or, how is it worked out?
Can I still use the TIP31C as suggested by Markd77? I like your idea of testing bit by bit. In this way I hope to understand the concept fully.
Your suggestion of using more than 1 IR LED emitter is interesting and I'll note it down for "future adventures"
Thanks alot for your time and help-John
