How to drive a cd rom spindle bldc motor without using a driver IC .
Discussion in 'General Electronics Chat' started by farazbhatti117, Jul 17, 2011.
  1. farazbhatti117
    Jul 16, 2011
    Hi .. I'm really a noob to motor driving so i'd like to be guided to driving a cd rom bldc spindle motor ... Using the coil inputs A1 A2 A3 i've managed to move the motor a little more than 180 degrees .. But it stops moving near the hall effect sensors .. I'm using a ckt having three half bridges to drive the motor to 180 + degress .. how can i get through the hall effect sensors ? Where do i feed in the hall sensor output and how to do i create the whole feedback circuit ? heres a picture
    http://www.ziva-vatra.com/imagecompatibility.php?render=Y2ltZzE5MjJfbW9kQDI2"/
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The Hall-effect sensors are what tells the motor controller which set of coils needs to be energized in what polarity.
    It also provides feedback as to the rotational speed of the platter.
    If you get it rotating too quickly, you may create a hazardous situation.
    Why don't you create a schematic of your current circuit and attach an image of it? .PNG images are preferred.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I would think that the best way to drive the motor is to employ a dedicated driver, or simulate the operation of such. Get yourself the data sheet of said devices and read them carefully.
