How to draw the following volume (not using matlab)
Discussion in 'Math' started by u-will-neva-no, Mar 28, 2012.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hey again!
    I have two surfaces: z = \sqrt{2}(x^2+y^2)  (1) and  x^2 + y^2 + z^2 = 1  (2)
    now I know that (1) is the shape of a paraboloid and (2) is a sphere but how do the two look together?
    I put x =0 and get z = \sqrt{2} and z = \frac{-1}{\sqrt{2}} but for y=0 I get an imaginary value for the x value (and also 4 solutions which is strange)
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    PM 1Chance...She can help.
    u-will-neva-no likes this.
  3. u-will-neva-no
    Mar 22, 2011
    230
    Sorry, I don't understand what you wrote.
  4. R!f@@
    Apr 2, 2009
    8,785
    771
    1Chance is the math wiz of AAC.
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    You know the equation of a circle is
    x^2 + y^2 = r^2
    Thus,
    x^2 + y^2 = 1
    is the equation of a circle with radius = 1
    Similarly,
    x^2 + y^2 + z^2= 1
    is the equation of a sphere with radius = 1
    See if you can figure out the shape of
    x^2 + y^2 = z
  6. panic mode
    Oct 10, 2011
    1,328
    305
    1) z=sqrt(2)(x^2+y^2)
    2) x^2+y^2+z^2=1
    rewrite last one as
    x^2+y^2=1-z^2
    and substitute in first one to get quadratic equation
    z=sqrt(2)(1-z^2)
    with solutions z=1/sqrt(2) and z=-sqrt(2)
    which are z values where surfaces intersect.
    use that z-value in both equations to get curves of intersection (circles).
    then freeze any one of variables to get section view.
    with few points calculated, just connect the dots.
  7. MrChips
    Oct 2, 2009
    12,623
    3,451
    just put square braces around tex
    in front of the equation
    and close with square braces around /tex
    like this
    {tex}z=sqrt2(1-z^2){/tex}
    but replace { } with [ ]
    and you will get
    z=sqrt2(1-z^2)
  8. panic mode
    Oct 10, 2011
    1,328
    305
    test:
     sqrt(1-z^2)
     sqrt x^5
     c=sqrt (a^2+b^2)
    cool ;-)
    thanks
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    panic mode likes this.
