How to distinguish between LEDs
Discussion in 'General Electronics Chat' started by gabrieldesloz, May 9, 2016.
  1. gabrieldesloz
    May 9, 2016
    I want to know what kind of tests can be done to distinguish between two leds of the same color, but with different characteristics (like luminous flux, for example).
    Thank you.
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    What are you trying to do?
    For luminous flux you would power both LEDs with the same fixed current and measure which is brighter..
    When powered you can also determine the forward voltage rating of each by measuring the drop across the LED..
  3. #12
    Nov 30, 2010
    16,665
    7,313
    When I needed a measurement of light intensity, I used a Minolta SLR camera.
    I had to weasel my way through some references to translate F-stops into lumens, but it's possible.
    On the other hand, you can probably get a light meter a lot cheaper than buying a whole camera.:D
  4. dannyf
    Sep 13, 2015
    2,196
    417
    Light them up?
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    If you want to get a more accurate value of Luminous Flux then you can buy the Luminous Flux Meter, or you just want to do a general judge not that accurate, you can using a LDR + voltage divider + op amp positive amplifier.
  6. wayneh
    Sep 9, 2010
    12,373
    3,225
    Put all your test LEDs in series with a current-limiting resistor. They'll all have the identical current. Then just look at them.
  7. ScottWang
    Aug 23, 2012
    4,925
    777
    Ha ha, just look at them, you got the good eyes ... :D
  8. wayneh
    Sep 9, 2010
    12,373
    3,225
    If you can't see a difference, who cares?
    #12 likes this.
