The first thing will be to check the datasheet for the pinout and whether it's common-anode or common-cathode.
Then you need to know how much the max. current for each LED, and you can go from there to determine if or what size of external resistor you will need for each LED.
ya,how to connect the 7 segment 2 the mux? do u noe any sites or links tat hav a schematic diagram of how 2 connect the legs of 7 segment, decoders, and mux?
Don't really need a schematic. Get the data sheets for the chips you are using and follow that information. The displays, whatever they are, will connect to the outputs of the display drivers, whatever they might be. The display drivers get their inputs from the MUX, whatever it might be. The MUX inputs have yet to be mentioned.
