How to discharge the capacitor?
Discussion in 'General Electronics Chat' started by samy555, Oct 21, 2015.
  1. samy555
    Thread Starter Active Member
    May 24, 2010
    116
    Hello
    From: http://www.talkingelectronics.com/projects/TheTransistorAmplifier/TheTransistorAmplifier-P2.html
    I've built the following circuit:
    In fact I used a 200K ohm resistor instead of 100K and a 1000uF capacitor and I had a delay time of about 3.5 minutes.
    The problem is when the main power off the 1000uF capacitor maintained its charge for long time and if the main power returned the circuit is ON immediately without any delay. How to discharge the capacitor?
    Thank you very much
  2. ronv
    Nov 12, 2008
    3,392
    1,448
    You could try a schottky diode across the 100K resistor with the anode to the + of the cap.
    samy555 likes this.
  3. samy555
    May 24, 2010
    116
    Yes
    excellent
    I try it and the cap. dischaged very fast
    thank you very very much
  4. GS3
    Sep 21, 2007
    408
    35
    This should work.
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    Even better; ditch the Darlington and replace it with a regular NFET (not logic level); That makes it possible to use a much smaller timing capacitor, and a much higher value for the timing resistor (now 100K). You can eliminate the 330K and the other resistor tied to the base of the Darlington, too.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Just put a diode in parallel with the 100k resistor - pointing upwards so its reverse biased when the capacitor is charging. When you switch off and the supply rail falls, any voltage left on the capacitor forward biases the diode and discharges through the other circuit elements.
