how to disassemble smd ic 12 pins without hot air station only with soldering iron 10watt
Discussion in 'General Electronics Chat' started by Ujwal Bhagat, Jan 31, 2016.
  1. Ujwal Bhagat
    Jan 30, 2016
    76
    Recently I have corrupted my laptop bios So I preferred the hot flash method as I have a desktop with same BIOS series chip. I desolder BIOS chip on both laptop and desktop. But while soldering wires to the desktop BIOS slot, accidentally the wet solder fall on the leads of the ic . I got continuity among that leads. Please help me desoldering it.
  2. Ujwal Bhagat
    Jan 30, 2016
    76
    Ic
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    You can sometimes use a soldering iron with a little solder on it to drag and pull solder bridges off.
    A better way is to use solder braid by putting a little solder on the braid and then holding the braid against the IC pins with the side of the soldering iron for the excess solder to be pulled into the braid.
    PeterCoxSmith and David Knight like this.
  4. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Take two 1mm Sq wire u form what fit over the contacts lot of solder and you lift the part of the print.
    use braid to clean the lot.
  5. Ujwal Bhagat
    Jan 30, 2016
    76
    I will try and post here
    Hmmmm... Can you draw it and post it here please
  6. hp1729
    Nov 23, 2015
    2,105
    235
    https://en.wikipedia.org/wiki/Desoldering
    Solder braid or solder wick
    Lay the braid against the solder you want to pick up. Apply heat to the braid. As the solder melts it gets sucked into the braid, flowing following the heat..
  7. SLK001
    Nov 29, 2011
    852
    243
    I second the solder braid method. Also CLEAN your circuit before you post a photo of it - and put LIGHT on your subject.
  8. Ujwal Bhagat
    Jan 30, 2016
    76
    Y
    Yup.....
