I have an inductor that burned up, which is part of the 12vdc main power. I don't have a schematic on this unit, so I don't have the slightest idea the value. The is feed right from the power supply to this inductor, and then on to the inverter for the inverter of a LCD. This is all surface mount devices.
I can ring test them, but of course this is burned out and can't. What measurements must be taken? Frequency?
Performed ring test on it, -0.5mh in circuit, of course it also suggests removal, this was performed on a working unit.
