I am going out of town for a week so I am designing an auto topoff for my fish tank. Some of you have already helped me with the first part of this which was using a 555 timer to filter out the rapid cycling of the pump motor associated with the float switch bobbing up and down on the surface of the water.
http://forum.allaboutcircuits.com/showthread.php?t=55428
The next part is to add a voltage monitor to the circuit to shut the top off down if my 12 volt battery gets too low. I want to avoid completely discharging the battery as it is an SLA and I believe discharging it completely can ruin it. I have a few TC54 voltage monitors laying around:
http://ww1.microchip.com/downloads/en/DeviceDoc/21434g.pdf
which I figured I could wire the input up to a voltage divider to shut everything down if the voltage across the battery terminals falls below....I don't know.....say 11 volts but it could be anything. My concern is that when the pump first turns on there is going to be a current surge which could cause the battery voltage to fall below 11 volts momentarily. I could see a situation where I would be back to the rapid cycling that I am trying to avoid. So I guess I am just looking for ideas on how I should approach this problem.
