how to determine the PWM frequency for Buck Converter?
Discussion in 'The Projects Forum' started by kaneneville, Oct 26, 2012.
  1. kaneneville
    Mar 7, 2009
    9
    I am designing a buck converter controlled by ATmega8 for solar power panels.
    What should I consider to determine the best PWM frequency for highest efficiency?
  2. kaneneville
    Mar 7, 2009
    9
    I found most of the DC-DC from maxim and TI are driving the mosfets at about 100k-200kHz. Some of them are constant frequency diving and some of them are not. Is it because of preventing high driving current at low duty cycle?
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    The PWM frequency is a tradeoff between output inductor and capacitor size, and the switching losses in the switch transistor. So just use the recommended or typical values in the data sheet and you should be fine.
    Be aware that the higher the switching frequency, the more critical the PCB layout is. Use the recommended layout in the data sheet for the controller if you can.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    There is also a cost penalty for higher freq in more expensive core materials for the magnetics. Also, EMI typically gets worse. There is generally a cost increase in gate drive circuitry because the reduced time period forces you to switch the gate faster, takes drivers that can push more peak current. As for capacitors: it's not just size, higher switch frequency forces the use of lower ESR caps which are more expensive in order to keep safe power dissipation. Above about 200 - 300 kHz, ceramic caps have to be used.
