How to determine polarity
Discussion in 'General Electronics Chat' started by Gdrumm, Jul 17, 2010.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I bought a used LCD monitor today, without a power supply.
    I have some power supplies that might work.
    The monitor is an HP F1703, but I cannot find the little icon that indicates positive inside - negative outside, or vise-versa, etc.
    There is a small icon (a solid line underscored by a dashed line)... is that an indicator of polarity?
    I've looked on HP's web site, but it's running as slow a christmas today.
    In any case, how can I determine the correct polarity required of a device, when there is no apparent indicator?
    Thanks,
    Gary
  2. tom66
    May 9, 2009
    2,613
    214
    The solid line/dashed line indicates DC.
    If you can open it up check if there is an input diode. Any good design will have a diode preventing damage from the wrong polarity. Then you can be safe in knowing you can insert the wrong tip polarity without damage. Do a continuity check using a multimeter to make sure that diode is the input diode.
    On a side note, most devices are centre tip positive.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
