how to determine if my pic16f877a ic is broken??
Discussion in 'General Electronics Chat' started by yuanshikai, Nov 5, 2011.
  1. yuanshikai
    Sep 17, 2011
    49
    how do I test if my ic is broken? and what connections can cause my pic to be broken?
  2. nigelwright7557
    May 10, 2008
    488
    71
    Write a very simple program, for it that switches an i/o port high and low.
    Over voltage into the chip will kill it.
  3. yuanshikai
    Sep 17, 2011
    49
    isn't the output on a pin of a port always 5V or 0V when the supply is 5V? my output pins read something like 0.5V..
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    If the pin is not configured as output, the voltage on the pin can be anything.
    If the pin is an output, 0.5V may not be terribly wrong. You have to check the specs for
    V_O_L.
    Do what post #2 says. Try to toggle an output pin.
  5. yuanshikai
    Sep 17, 2011
    49
    it seems my ic really is broken, but what could have caused this this in my circuit?
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    I cannot read the values of R1 and R2. I would replace both with a 5V regulator such as a 7805.
  7. yuanshikai
    Sep 17, 2011
    49
    this is supposed to be a voltmeter and the voltage to be tested was the 9V source. R2 is 2Mohms and R1 is 100kohms..
  8. MrChips
    Oct 2, 2009
    12,624
    3,451
    Sorry, I thought that was your 5V supply.
  9. yuanshikai
    Sep 17, 2011
    49
    it's not shown in the image but my voltage supply for the pic is 5V btw.
  10. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I don't see any limiting resistors between the PIC outputs driving the 7 segment displays, meaning you have a very large current into each LED. That will pop the PIC in short order.
    Just before it blows the output pins will have the LED on voltage at them, depending on the display something like 1.5 volts.
  11. yuanshikai
    Sep 17, 2011
    49
    :( damn.. thanks alot.. what value should the limiting resistors be..
  12. spinnaker
    Oct 29, 2009
    5,065
    1,176
    It will depend on the forward voltage of your LEDs, your supply and the amount of current the LED and PIC can handle.
    http://blog.datasingularity.com/?p=243
