How to determine AC/DC
Discussion in 'General Electronics Chat' started by TimCollins, Oct 19, 2011.
  1. TimCollins
    Sep 19, 2011
    9
    I have a question. I have a small electric motor out of an old jukebox that I think is bad. I found the wiring diagram telling me the motor circuit is 28VDC. However, before I found the diagram I was using a voltmeter testing the plug into the motor and I got about 30VDC however, when I switched the voltmeter to AC I also got a reading of about 13.5VAC. So... my question is, if I did not have the wiring diagram how would I know whether the circuit was AC or DC because I am getting what looks like valid readings from both on my meter?
    Thanks in advance for any help...
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do you have a couple of LEDs and a 1/4W 5.6k resistor?
    If so, wire the LED's back-to-back (anode to cathode, cathode to anode) in parallel, and the 5.6k resistor in series with them.
    Then connect that across the voltage.
    If both LEDs light, then it's AC. If only one lights, it's DC.
    PackratKing likes this.
  3. K7GUH
    Member
    Jan 28, 2011
    191
    23
    You could look at the waveform at various points in the circuit, using an oscilloscope. Otherwise, you may have to do a lot of guesswork. I should think that a pulsating d.c. current would give you both d.c. and a.c. readings on some types of meter.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oscilloscopes are great - if you happen to have one. Since this board is oriented towards beginning to intermediate level hobbyists, most of the members won't have an O'scope handy.
    A couple of LEDs and a resistor is pretty low tech, but it's cheap, easy, and will get the job done.
  5. TimCollins
    Sep 19, 2011
    9
    Thanks for your answers. I was hoping there was an easy way that maybe I just didn't know about. But, you have answered my question. Thanks!
  6. colinb
    Jun 15, 2011
    351
    35
    Maybe the ac voltage is actually a result of the back emf produced by the motor.
    Did you measure the 30 V dc / 13.5 V ac with the motor connected and running? Try measuring the voltage with the motor disconnected so that back emf is not a factor. And/or try measuring the voltage with the motor connected but stalled (hold the rotor stationary).
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The "old jukebox" may be running the DC motor from rectified AC but with no filter caps. That was common in some 1950's equipment, I have a 1950's battery charger that does the same thing.
