How to detect
Discussion in 'The Projects Forum' started by Vladek, Apr 25, 2006.
  1. Vladek
    Apr 25, 2006
    I generally understand electronics but just do not know what element(s) to use in this case:
    There is a little 555 circuit (oscillator) running from just 3 Volt supply and I need to detect when the supply current reaches certain level.
    I inserted 1 kOhm resistor between the ground pin (1) and the supply ground and as the oscillator changes its frequency the voltage drop across this resistor goes from 0.1 V to 0.8 V.
    I need level of around 0.4 V to trigger another circuit but the detection should not affect the measured voltage significantly, i.e. it should not draw more then microamps.
    The circuit triggered by the 0.4 Volt threshold will be running at 9 or 12 Volts.
    I feel I should use a FET device but do not have any experience with these transistors, or perhaps an op-amp?
    Could anyone help by describing a practical, simple circuit - what voltages at gate, drain and source, or ???
    BTW: I experimented with a LED instead of the 1 kOhm resistor and it lights brighter as the voltage rises and I could follow this using some phototransisor, even try to set detection point by inserting a optical obstruction but there must be a more elegant way -:)
    Thank you for your attention.
    Vladek
  2. windoze killa
    Feb 23, 2006
    605
    24
    First off I wouldn't try the LED and phototransistor method. Any change in ambient light will cause a change in the O/P of the phototransistor.
    Now for the rest of it. I am not sure where you have placed this resistor and what supply current you are talking about. Can you provide a schematic of your design to help us work this out for you.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  4. mozikluv
    Jan 22, 2004
    1,437
    hi,
    as what "thingmaker3" has suggested it will and i might add another 555 will also do it for you.
    by the way at what frequency is your oscillator operating?
    moz
  5. Vladek
    Apr 25, 2006
  6. windoze killa
    Feb 23, 2006
    605
    24
  7. dragan733
    Dec 12, 2004
    152
    Here in the attachment is the solution using a comparator
  8. Mazaag
    Oct 23, 2004
    255
    Hi Dragan773,
    I just looked at your solution and I just wanted to ask about the purpose of R4 at the output of Opamp.. is it like a pull up or pull down resistor ? if so , please explain in detail the reason for it.
  9. dragan733
    Dec 12, 2004
    152
    Hi mazaaq,
    because all comparators are with open colector, therefore the output resistor R4 goes to +supply.
    I did a change in the schematic, see it again
  10. Mazaag
    Oct 23, 2004
    255
    Hi Dragan..
    thanks for your reply..but i'm not quite sure what you mean...
    could you please explain it in more detail ?
    P.s: i'm a noob.
  11. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Mazzag,
    Look at the attached diagram from the LM193 Application Note.
    You will see the output of the comparator has an open collector.
